82 kz550c Ltd Ignition Wiring
- aarb77
03 Jul 2015 13:27 - 03 Jul 2015 16:26
Okay KZRIDER friends I need help to get my bike on the road. The two pictures I sketched up on my wiring are included. This is my first time wiring so be gentle. With everything wired up my starter solenoid relay if popping when when I hit the ignition switch but no firing. I'm thinking the on\off switch is my problem but not sure. I am currently running original coils, points, IC ignitor, regulator, stator, relay, and starter motor. The wiring diagram represents the original color coding on the wire. Thanks in advance for the help let me know if you need any more info or pics.
RB
Last edit: 03 Jul 2015 16:26 by aarb77.
- aarb77
