battery question
- monkeydoodle
battery question
22 Jun 2015 11:57
OK this is one for the electrical guys out there. Is it possible to use a gel or AGM battery instead of the regular lead acid on the KZ's without too much issue?
I was advised that if I was to use either a gel or AGM battery then I would have issues due to the charging system on the KZ being set up for lead acid....now this is completely over my head which I don't mind admitting.
Your thoughts are greatly appreciated.
Custom Harley Chop
2004 Fazer 1000 with Ivans Full Monty kit
1980 Z750E (half way being re-born into a mix breed something)
- pete greek1
Re: battery question
22 Jun 2015 12:44
Many people on here use them with no issues , just know that you'll have to get a special charger, you cant use a lead acid battery charger, but many have said they've gone over 2 yrs. without having to charge em
Pete
Pete
- loudhvx
22 Jun 2015 12:59
AGM and gel batteries are lead-acid batteries, so there is nor problem with using lead-acid battery chargers.
The issue comes when you switch over to a lithium type battery. Then special chargers are sometimes recommended.
batterystuff.com has a few options for AGM batteries that last really well. It's the Scorpion brand.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: missionkz
- Irish Yobbo
22 Jun 2015 21:07
Even some lithium types are fine, and can be charged with a normal charger. I use a SSB Powersport Lithium battery - 220CCA and 600g. Works a treat.
1981 KZ750 LTD
- monkeydoodle
22 Jun 2015 22:59
OK so the battery that is fitted as standard to my 750 is a 12V 12AH 160A - do I get the equivalent in AGM or GEL?
thanks again
thanks again
Custom Harley Chop
- bountyhunter
23 Jun 2015 00:08 - 23 Jun 2015 00:09
I think AGM is the best bang for the buck.
I run this one.
www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
I run this one.
Last edit: 23 Jun 2015 00:09 by bountyhunter.
- Tyrell Corp
23 Jun 2015 03:37
I like motobatt, the yellow gel ones. A bit early to say how long they last other than they have a better open circuit and cold cranking capacity. I think it is a YB12 for that, same as the 550's.
- monkeydoodle
23 Jun 2015 05:08
Cheers guys spotted the motto batt on ebay , was told by my usual supplier that yuasa, leoch, varta and another manufacturer do not stock a gel or agm fir the kz750 as allegedly the battery requires a breather ??
Custom Harley Chop
- pete greek1
23 Jun 2015 08:36
O K. glad Loudvx caught that...I was having a Brain Fart...when you mentioned Gel, I was thinking Lithium, :blink: :blink:
- loudhvx
23 Jun 2015 12:53
AGM is a sealed battery, so you do away with the breather and spill hose assembly. This is the main reason I switched over. The breather fumes, alone, can cause corrosion if there is even a slight scratch in the paint on the frame.
Some KZ's had battery indicator lights on the dashboard. That requires a sensor in the wet-cell battery to monitor the acid level. Since the AGM is sealed, you don't need that circuit anymore. If you have the sensor wire, it just gets connected to a switched-12v wire to stop the light from flashing (if your bike has that feature).
1981 KZ550 D1 gpz.
Other links.
Other links.
- monkeydoodle
23 Jun 2015 13:12
thanks for the replies guys. One more question, can I use a smaller battery. Basically I want to try and get one that is physically smaller. I know that the KZ is a 12V and has 12 ha and 160 amps but could I go for something that is 12V and and has less ah and still be around 160A or is that not possible?
Custom Harley Chop
- bountyhunter
23 Jun 2015 15:21You can get the same A-hr and CCA with a smaller battery if you use lithium. But if you stay with lead acid, they will all be close to the same size and weight for a specific A-hr rating. You don't want to go down on A-hr or CCA, going HIGHER is always good, not lower.monkeydoodle wrote: thanks for the replies guys. One more question, can I use a smaller battery. Basically I want to try and get one that is physically smaller. I know that the KZ is a 12V and has 12 ha and 160 amps but could I go for something that is 12V and and has less ah and still be around 160A or is that not possible?
