battery question
  • monkeydoodle
  • Topic Author
22 Jun 2015 11:57 #677769 by monkeydoodle
battery question was created by monkeydoodle
OK this is one for the electrical guys out there. Is it possible to use a gel or AGM battery instead of the regular lead acid on the KZ's without too much issue?
I was advised that if I was to use either a gel or AGM battery then I would have issues due to the charging system on the KZ being set up for lead acid....now this is completely over my head which I don't mind admitting.
Your thoughts are greatly appreciated.
Custom Harley Chop
2004 Fazer 1000 with Ivans Full Monty kit
1980 Z750E (half way being re-born into a mix breed something)
22 Jun 2015 12:44 #677772 by pete greek1
Replied by pete greek1 on topic battery question
Many people on here use them with no issues , just know that you'll have to get a special charger, you cant use a lead acid battery charger, but many have said they've gone over 2 yrs. without having to charge em
Pete
22 Jun 2015 12:59 #677779 by loudhvx
Replied by loudhvx on topic battery question
AGM and gel batteries are lead-acid batteries, so there is nor problem with using lead-acid battery chargers.
The issue comes when you switch over to a lithium type battery. Then special chargers are sometimes recommended.
batterystuff.com has a few options for AGM batteries that last really well. It's the Scorpion brand.
The following user(s) said Thank You: missionkz
22 Jun 2015 21:07 #677829 by Irish Yobbo
Replied by Irish Yobbo on topic battery question
Even some lithium types are fine, and can be charged with a normal charger. I use a SSB Powersport Lithium battery - 220CCA and 600g. Works a treat.
1981 KZ750 LTD
  • monkeydoodle
  • Topic Author
22 Jun 2015 22:59 #677836 by monkeydoodle
Replied by monkeydoodle on topic battery question
OK so the battery that is fitted as standard to my 750 is a 12V 12AH 160A - do I get the equivalent in AGM or GEL?
thanks again
Custom Harley Chop
23 Jun 2015 00:08 - 23 Jun 2015 00:09 #677838 by bountyhunter
Replied by bountyhunter on topic battery question
I think AGM is the best bang for the buck.
I run this one.
www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
Last edit: 23 Jun 2015 00:09 by bountyhunter.
  • Tyrell Corp
23 Jun 2015 03:37 #677845 by Tyrell Corp
Replied by Tyrell Corp on topic battery question
I like motobatt, the yellow gel ones. A bit early to say how long they last other than they have a better open circuit and cold cranking capacity. I think it is a YB12 for that, same as the 550's.
  • monkeydoodle
  • Topic Author
23 Jun 2015 05:08 #677852 by monkeydoodle
Cheers guys spotted the motto batt on ebay , was told by my usual supplier that yuasa, leoch, varta and another manufacturer do not stock a gel or agm fir the kz750 as allegedly the battery requires a breather ??
Custom Harley Chop
23 Jun 2015 08:36 #677882 by pete greek1
O K. glad Loudvx caught that...I was having a Brain Fart...when you mentioned Gel, I was thinking Lithium, :blink: :blink:
23 Jun 2015 12:53 #677931 by loudhvx
AGM is a sealed battery, so you do away with the breather and spill hose assembly. This is the main reason I switched over. The breather fumes, alone, can cause corrosion if there is even a slight scratch in the paint on the frame.
Some KZ's had battery indicator lights on the dashboard. That requires a sensor in the wet-cell battery to monitor the acid level. Since the AGM is sealed, you don't need that circuit anymore. If you have the sensor wire, it just gets connected to a switched-12v wire to stop the light from flashing (if your bike has that feature).
  • monkeydoodle
  • Topic Author
23 Jun 2015 13:12 #677936 by monkeydoodle
thanks for the replies guys. One more question, can I use a smaller battery. Basically I want to try and get one that is physically smaller. I know that the KZ is a 12V and has 12 ha and 160 amps but could I go for something that is 12V and and has less ah and still be around 160A or is that not possible?
Custom Harley Chop
23 Jun 2015 15:21 #677959 by bountyhunter
monkeydoodle wrote: thanks for the replies guys. One more question, can I use a smaller battery. Basically I want to try and get one that is physically smaller. I know that the KZ is a 12V and has 12 ha and 160 amps but could I go for something that is 12V and and has less ah and still be around 160A or is that not possible?
You can get the same A-hr and CCA with a smaller battery if you use lithium. But if you stay with lead acid, they will all be close to the same size and weight for a specific A-hr rating. You don't want to go down on A-hr or CCA, going HIGHER is always good, not lower.
