Green Dyna Coils
  • skooterbum4real
  • skooterbum4real's Avatar Topic Author
Green Dyna Coils
19 Jun 2015 07:06
#677254
Can I temporarily run the green Dyna coils on a point system bike ??
1978 KZ650B 8,500 miles
1976 KZ750 Twin
SPECIAL CONSTRUCTION V-TWIN CHOP
  • Jussumguy
  • Jussumguy's Avatar
Re: Green Dyna Coils
19 Jun 2015 08:18
#677262
Hi
According to Motörrad elektrik website the green coils will work with points
Good luck!
The following user(s) said Thank You: skooterbum4real
  • MFolks
  • MFolks's Avatar
19 Jun 2015 11:14
#677279
You'll need to change the primary(small wires) side connection from push on to ring style terminals. The original wiring was maybe 22-18 gauge, so the RED insulation ring terminals should work, just make sure the proper terminal crimper is used. Avoid any solder on these terminals, as it will "wick" up inside the wire insulation, making it stiff, and prone to breakage from vibration.
  • missionkz
  • missionkz's Avatar
19 Jun 2015 11:46 - 19 Jun 2015 11:47
#677287
I've heard you can run the 3 ohm coils with points.
They will sink a lot of current though....
Until I get time to exchange my points plate with my new Dyna S... I am still running my standard points with the green Dyna coils.
However, I am also running a home made ballast resistor in series with the 12v to the two coils. It is 1.8 ohms @ 100 watts and gets amazingly warm for what it is!!
Yet it works perfectly.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 19 Jun 2015 11:47 by missionkz.
  • skooterbum4real
19 Jun 2015 23:34
#677376
Thanks for the info guys !!
1976 KZ750 Twin
  • Tyrell Corp
  • Tyrell Corp's Avatar
20 Jun 2015 06:14
#677391
Whatever you do, if using Dyna S, make it an unbreakable habit that the kill switch is ALWAYS off unless running.
Leaving the ignition switch on by mistake can cook the expensive coils I've done it a couple of times by mistake and got lucky, but they did get really hot.
  • skooterbum4real
20 Jun 2015 21:25
#677517
I tried to start my new, old, 78 kz650 the other day, and it didn't start. What a let down. I discovered there was no spark at the plugs. I decided I needed to check the coils to see if there were any problems there, and sure enough, one of the coils is junk. The bike has set for over 15 years in a barn, so this really doesn't surprise me.
So I got my nice green used Dyna coils out that I recently acquired, and gave them a quick check. One of them is junk as well........
My last hope was a set of coils I got off of an 82 kz650 electronic ignition bike. They both checked out OK !!
But I'm betting I cannot use these on my points ignition bike, can I ?? They checked out at 2.6 and 12.6, where the original, good coil from the points bike checks out at 4.5 and 15.5.
What a pain !!
Can someone please tell me what bike would be a good choice, to get a used set of coils from, that would work on this 78 points bike ?? Preferably a bike that's a lot newer than mine......
1976 KZ750 Twin
  • loudhvx
  • loudhvx's Avatar
21 Jun 2015 09:41 - 21 Jun 2015 10:01
#677589
Unfortunately, there is likely no coil on a new bike that can just be swapped into a Kz650 points ignition. The emgo 4 ohm coils are the best bet if you want to save money. They are hard to find in stock, but someone may have a link handy. There are also no-name brand ones similar to the Emgo's.
i think I saw some available for about $40 or even less, each.
Last edit: 21 Jun 2015 10:01 by loudhvx.
