Locally sourced Ign Wires
  • The_Proletariat
  • The_Proletariat's Avatar Topic Author
  • "Cocaine is a hell of a drug"
14 Jun 2015 21:02
#676612
I discovered a spark plug wire that was leaking voltage. It gave me a nasty shock if I touched a particular spot of the spark plug end boot.
Instead of ordering more Dyna wires to replace my set that had already failed in less than 2,000 miles I went to the auto parts store and bought a set of universal 4 cylinder Ign wires. They were the Omni Spark brand, about $12, 7mm copper core.
The reason I am posting this is they came with GM HEI 90* boots that make cable routing much easier. With a little grease, the HEI boots slip over my Dyna coil outputs and there is enough room to use a small zip tie to secure the boot on the coil. With 90* boots I found it is easier to insert the crimped wire end into the coil and then slide the boot onto the coil.
1982 Kawasaki KZ550 LTD
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Locally sourced Ign Wires
15 Jun 2015 02:47
#676628
My expensive Taylor spiro pro leads failed within 1000 miles, not good.
Now I use 7mm copper off the roll and non resistor caps. Also the wire resistance is lower.
