Ignition Switch Disassembly
  • The_Proletariat
  • The_Proletariat's Avatar Topic Author
  • "Cocaine is a hell of a drug"
06 Jun 2015 20:24 - 06 Jun 2015 20:27
#675559
If you ever take your ignition switch apart, do it inside a box or enclosed container. It contains two spring loaded ball bearings that will shoot out when you pry off the plastic retainer cap.
What ever you do, do not do this outside, at dusk, while holding it over a mesh patio table.
1982 Kawasaki KZ550 LTD
Last edit: 06 Jun 2015 20:27 by The_Proletariat.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ignition Switch Disassembly
06 Jun 2015 21:43
#675563
So it went sproing on you? :lol: Did you find the parts?
  • bountyhunter
  • bountyhunter's Avatar
06 Jun 2015 23:25
#675568
Don't do it over a shag rug either.
Guess how I know....
  • The_Proletariat
08 Jun 2015 04:38
#675688
I took it apart due to a flickering taillight that I traced to the switch.
I was able to find all the parts that shot out however after a while of searching I was very close to getting a toggle switch from the auto parts store.
