KZ550-C1 Starter Problems
  • Animenima
  • Animenima's Avatar Topic Author
30 May 2015 15:55
#674541
For a while my starter was only working half the time and would just buzz the other half of the time. Now it doesn't do anything at all. I checked the switch, and I checked the solenoid. Everything seems to be working fine, so I'm guessing the starter went bad. Only problem is that I don't know where the starter is. The wire from the solenoid looks like it goes into the crankcase or near there, but I can't tell. Any help at all is appreciated. Will provide pictures when I can.
Re: KZ550-C1 Starter Problems
30 May 2015 16:12
#674542
Welcome aboard! You need to buy a Kawasaki Service Manual. Be sure to get one for your bike's exact year & model. They usually are available on eBay. I would not recommend working on the bike without one as it contains all the information you will need to perform tasks correctly. Ed
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 May 2015 16:37
#674547
The buzzing sound can be the battery. Check that first.
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
01 Jun 2015 18:58
#674877
The starter is behind the sprocket cover, under a chrome starter cover under the carbs.
Check the battery voltage before you condemn the starter.
1982 Kawasaki KZ550 LTD
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jun 2015 19:08
#674880
A battery with a dead cell can measure 12 volts but will not have the AMP's to turn a starter.
