tail light stuck on?
  • oldsguy
  • oldsguy's Avatar Topic Author
24 May 2015 18:17
#673564
Everything was normal, then the stop light on gauge tree came on. Cant find problem. Brakes are not stuck and lever and pedal work fine.
  • TexasKZ
  • TexasKZ's Avatar
Re: tail light stuck on?
24 May 2015 18:37
#673569
Brake light failure?
24 May 2015 19:33
#673582
Is this problem on an Oldsmobile, motorcycle, or what? :lol: PLEASE add you bike's model and year to your signature line. Ed
The following user(s) said Thank You: oldsguy
  • martin_csr
  • martin_csr's Avatar
24 May 2015 20:05
#673586
Does the rear brake light illuminate? The problem could be as simple as a bad bulb.
The owner's manual describes the functionality of the brake indicator light. Some new KZ riders don't realize the om is kinda hidden in a pull-down document case on the underside of the seat.
  • oldsguy
25 May 2015 03:12
#673598
Sorry Ed, new to this site..ill get it eventually. Thanks for info, I will change bulb, took it out and it looked fine. Also bulb indicator light info in om is vague. Also having problem finding front directionals that fit off the headlight. Bike came with fairing that im not using, and the direct stems wont fit..studs are to big...any ideas?
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • martin_csr
25 May 2015 06:04 - 25 May 2015 07:29
#673606
If the rear brake light works, then changing the bulb probably isn't the answer.
If the stop lamp/warning light is on all the time, the problem could be a brake light switch --- one of them may be stuck in the ON position or may be defective, or the rear brake light switch may need adjustment (but the rear brake light would be on as well).
During normal operation, the gauge stop lamp should come on when the brake is applied --- this tells you the brake light is working, so you won't get rear ended. The outage indicator switch or brake light failure switch is supposed to flash the stop lamp warning light to indicate that the brake light isn't working --- the stop lamp should still come on when the brake is applied, but after releasing the brake, the stop lamp should flash.
Last edit: 25 May 2015 07:29 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 May 2015 06:20
#673607
I'd unplug them one by one to isolate the problem. If it turns out they aren't the problem, then it's the relay. It's solid state and have to be replaced.
25 May 2015 06:50
#673609
No eBay APP ID and/or Cert ID defined in Kunena configurationThanks for adding the info to your signature line. :)
If nothing else seems to correct the problem you may want to check the outage indicator switch. Here's a picture of one in an eBay listing. See
Here's what it looks like in the parts diagram. Ed
Attachment 00003a-38.jpg not found
  • oldsguy
26 May 2015 15:13
#673893
Thanks for all the responses, fixed the problem. Rear stop light button is sticking..gonna spray alittle wd40 on end and see if i can free it up.
26 May 2015 15:17
#673895
WAIT! I would not use WD-40 on that. WD-40 will eventually dry and create an insulating film. If you do a search on this site you'll will see details on the problems. Use DeOxit (Radio Shack carries it) or some other quality contact cleaner. Ed
Attachment DEOXIT-2.jpg not found
  • oldsguy
26 May 2015 16:00
#673909
Thanks Ed..appreciate it.
