Quick question here. The instructions for wiring in the combo rectifier/regulator says one wire goes to Battery (+). Now, the original divorced units provided the charging power through a fuse and then to the run switch.
Should this new unit go straight to the battery or back through the way the old stuff was? I don't want any weird battery drain with the key off or anything...
EDIT: Nevermind. Too much fun this weekend. I missed in the diagram the splice to the battery directly before the fuse.
1977 KZ650-B1
Last edit: 24 May 2015 16:35 by Twilightoptics.
