82 GPZ750, battery sensor questiom
- Jrider
23 May 2015 09:38
I just bought a battery for the gpz750. It comes with a wire that is supposed to be inserted into on of the battery cells on one end and the other end has an electrical connector. It is supposed to be a battery sensor to feed info to the LCD display on the dash. Where the the electrical end connect to? Is it necessary? Help.
1982 Kawasaki KZ 750 R , Stock
2007 Harley Davidson Police Electraglide
- riturbo
Re: 82 GPZ750, battery sensor questiom
23 May 2015 12:33
Should be a green wire on the throttle side under the side cover. Its necessary if you dont want the light to blink. You can also just connect the wire to the pos side of the battery if you dont have the sensor for the bat . Thats how mine is set up so the light wont blink
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
