help finding out what goes into plug kz900
- Landfair
21 May 2015 13:05
Can anyone tell me what plugs into This? This is or of the only places I don't have whatever plugs into it. Any help would be greatly appriciated!
06 Ninja 650r
76 kz900 motor and parts 80 kz1000 frame (project)
Ktm 520 supermoto
01 katana (for sale)
Ktm 520 supermoto
Re: help finding out what goes into plug kz900
21 May 2015 17:34
Do you have your tail light hooked up? Or it might be a reserve lighting plugin.
- Landfair
21 May 2015 18:06
It looks like the reserve lighting Is a ppossibility. If anyone!has a kz and could Check that would be awesome if not I'll have to find someone with a bike and look at theirs. Thanks for the help though swest!
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
- Kapahulu
21 May 2015 18:36
My KZ900 is in the storage locker- I don't have it here to look at. Checking the wiring diagram, I think that plug is for the accessory lighting - the bulbs to the speedo, tach etc.
2strokeworld.com
2strokeworld.com
21 May 2015 18:47
I think you're right. The fuse block. A whit wire goes in there but has bullet connectors.
- Landfair
26 May 2015 13:49
Sorry I wasn't clear it's towards the back of the bike like under the seat so it's not the fuse box unless there are two. It comes out of the main harness Under the seat
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
26 May 2015 15:25
It's the fuse block. I stole one off a donor loom after the wreck in hopes of curing the hot fuse problem. No good all the juice goes through the main fuse anyway. I'm now using relays.
- Landfair
26 May 2015 15:46
Your right thanks! I had the fuse block plugged into the ignition :laugh:
06 Ninja 650r
Ktm 520 supermoto
Ktm 520 supermoto
