Starter switch
  • jf6933
  • jf6933's Avatar Topic Author
  • Current Bike 1985 ZN 700
Starter switch
18 May 2015 17:42
#672665
So I'm about to kick my bike over. I changed handle bars and now the starter switch does not work. Ugh help me please
1982 Yamaha Virago 750
2004 Honda Shadow 650
2006 Harley Davidson Sportster 1200
1982 Yamaha Maxim 750
Current And My Favorite 1985 Kawasaki ZN 700
  • Mat429
  • Mat429's Avatar
Re: Starter switch
18 May 2015 23:06
#672693
The same thing happened to me when i changed my bars. For some reason the ground my bike had on the triple clamps just went bad. Moved it and everything worked fine again. I would look for ground problems. Hope it helps.
The following user(s) said Thank You: jf6933
  • jf6933
Re: Starter switch
19 May 2015 08:09
#672716
I never hooked up the clutch lever switch. I just now thought of it. But it should still start in nuetral right?
Re: Starter switch
19 May 2015 08:43
#672724
The clutch lever lockout switch is just that - a switch. It does not know or care what gear the tranny is in. If the switch is in the off position (as though the clutch lever is not pulled in) the electric starter will not work. Ed
  • jf6933
Re: Starter switch
19 May 2015 09:05
#672730
thanks Ed. I will be trying it tonight after work.
