elp..Speedometer Problems
- Motiorcycle Michael
- Motorcycle Michael
12 May 2015 00:59
I've attempted this now with 2 different speedos and my bike guru does not have any idea whats causing this issue.
Any suggestions ? I welcome all ideas and suggestions!!
Thanx
Motorcycle Michael
Chino Valley, Az.
Michael Orley
- Randombeat
- 0 to 100 real quick...
Re: elp..Speedometer Problems
12 May 2015 02:05
Wrong ratio on the new speedo?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- weales
12 May 2015 05:08 - 12 May 2015 22:57
Maybe the speedo INNER cable is too long? Instead of the magnetic eddy currents from the rotating magnet driving the needle, the rotating cable INNER is pushing the magnet against the "cup" which carries the needle causing it to rotate at a much higher rate than it should be...? - just a suggestion, the gap between the magnet and the "cup" is not very much and it doesn't take much for these two items to touch, thus causing the needle to be driven directly by the cable.
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
Last edit: 12 May 2015 22:57 by weales. Reason: add detail
12 May 2015 05:34 - 12 May 2015 06:13
What speedos have been tried? If non-stock, KZs use the 2240-type of speedometers used on most if not all Japanese motorcycles.
Last edit: 12 May 2015 06:13 by martin_csr.
The following user(s) said Thank You: Motiorcycle Michael
