Name this wire
- david-b
- I am THAT guy
Name this wire
11 May 2015 19:47
Hey all,
Finally got the bike altogether after the starter issues and she's running great! Actually got her around the block a couple times this evening. Only thing, I can't find where this wire below goes to. It's a tan color and has the round connector on it, so I'm thinking it goes to the frame. As far as I can tell, everything works perfect so have no idea what it's supposed to go to. Looking at the wiring diagrams, the only thing I can find is the rear brake light, however that already has a tan wire going to it.
Any help? Thanks!
Any help? Thanks!
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
- Tyrell Corp
Re: Name this wire
12 May 2015 08:43
You say Tan colour, are you sure it isn't pink that has discoloured? if so it might be the battery voltage sensor.
Just looking at the colours on your tank graphics, the blue looks lighter than the standard dark blue...Is it paint or a decal. and do you know if it is original?
- JimB
Re: Re:Name this wire
12 May 2015 09:41
I agree it looks like the voltage sensor wire which would be pink and connects to the bel artery. Where does the wire go to at the other end?
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
- david-b
- I am THAT guy
Re: Name this wire
12 May 2015 12:50
It may be discolored, just like everything else on this bike.
However, when the bike is running, if I press the voltage button I get a reading on the volt gauge.
I was unable to trace to where it goes without taking apart that whole loom. Should I try connecting to the battery and see what happens? Would it be (+) or (-)?
The tank is from a GPz, no clue how original all the colors and stuff on there are.
/Dave
- missionkz
Re: Name this wire
12 May 2015 13:32
Yikes.... If you do that... at least use a voltmeter first or put a 12v bulb in series with it in case it is hot with battery voltage.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
