Help! Wiring diagram showing starter lockout?
- TheForumTroll
08 May 2015 03:48
Anyone have a wiring diagram that shows the starter wiring? The filebase seems to have been taken down and I'm not at home so no service manual :ohmy:
It is for a KZ700-A1 (or KZ750). I need to short it to make the bike run
-[ KZ700-A1 '84 ]-
- JR
Re: Help! Wiring diagram showing starter lockout?
08 May 2015 04:09 - 08 May 2015 04:25
gonna try to attach a pdf.
pdf attachment failed.
send me pm with email address
Last edit: 08 May 2015 04:25 by JR.
The following user(s) said Thank You: TheForumTroll
08 May 2015 07:18
Here's a site w/ a pdf manual & wiring diagrams.
mbsween.bike-night KZ750L3 page
Scroll down & click "The Bible" link.
Note: not applicable to the KZ700, but some of the wiring diagrams are mislabeled in the links.
The 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4. .... search tags mbsween KZ750L3.
- missionkz
08 May 2015 11:41
Are you talking about the starter lock out on the clutch lever? If yes, just peel the rubber cover back and temporarily wrap a piece of bare copper wire around the two terminals.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- OnkelB
08 May 2015 11:43
Follow the wires from the lockout switch on the clutch lever perch down to where they connect to the harness - it should be under the tank just below the left front tank rubber mount.
To bypass the lockout switch just unplug the two switch wires and connect the two remaining wires (most likely black) to each other,
77 KZ 650 B1, 82 GPz 1100 B2.
