Turn signals
  • DobbinsCMA
  • DobbinsCMA's Avatar Topic Author
Turn signals
30 Apr 2015 09:43
#670124
I put my turn signals back on and they don't seem to want to flash...will light up but won't flash. Did I forget to hook up the right relay? I didn't omit anything. Did the cylinder flash thing (lol I'm totally dumb) stop working or broke in transit? I checked the wiring diagram and all seems well. Hazards don't flash either.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
  • missionkz
  • missionkz's Avatar
Re: Turn signals
30 Apr 2015 10:06 - 30 Apr 2015 10:10
#670128
Check the actual flasher unit.... cylinder with two prongs on it.
Called a turn signal or flasher relay.....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 30 Apr 2015 10:10 by missionkz.
Re: Turn signals
30 Apr 2015 11:02 - 30 Apr 2015 11:03
#670133
Is your battery fully charged? With the original flasher unit, the turn signals on my bike would light but not flash unless the battery was fully charged. I replaced the flasher unit with a Tridon/Stant 552 2 prong electronic flasher (nearly any car parts store sells them for less than $10) and now they flash at a constant speed even if the battery is a little low. Ed
Last edit: 30 Apr 2015 11:03 by 650ed.
  • jakedude
  • jakedude's Avatar
Re: Turn signals
30 Apr 2015 12:38
#670140
Did you replace standard bulbs with LED bulbs? Many flashers have to draw enough current to get the flasher to flash. LEDs don't draw enough current. You have to buy an LED flasher.
Nothing lasts, nothing is finished, and nothing is perfect.
The following user(s) said Thank You: missionkz
  • DobbinsCMA
Re: Turn signals
02 May 2015 11:21
#670389
Battery is brand new and holding great current. I'm no wiring guru so I'll check to see if the relays are working. If not, I'll replace as they are pretty cheap. Also stock lights though I do want to go aftermarket to a low draw system.
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H :(
