1982 KZ1000 cop alternator rotor needed & puller
  • dnaj11
  • dnaj11's Avatar Topic Author
26 Apr 2015 08:50
#669612
The noise in my bike was identified in a previous thread. I have damaged magnets in my alternator rotor, looks like someone attempted to glue them back in place, one shook loose.
I'm looking for advise on pulling the rotor. I have the nut loose. Clymer's says the large bolt to match the outer diameter thread will work, Does anyone know the thread diameter and pitch or shall I try a standard puller?
Also, I've read here that rotors are hard to find. There is one on ebay right now,, but I don't know if it is the same. See item no. 201335096680 or any advise on a source is appreciated.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: 1982 KZ1000 cop alternator rotor needed & puller
26 Apr 2015 09:20
#669615
The 201335096680 rotor would fit, but the starter clutch mount disk on the back may be larger diameter than the one on yours, so your starter clutch (or the correct one for the bike) probably won't fit...verify that information with the seller.
See ebay item 200986746824...rotor removal bolt. Place a 3/8"(?) steel ball (bearing) in the bolt hole first, so the pressure exerts against the center of the crank vs. the whole end surface.
Hopefully this helps, but verify everything...before doing anything!
1982 KZ1100-A2/1170 sleeper 😀
The following user(s) said Thank You: dnaj11
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
28 Apr 2015 06:11
#669847
This is the third time I tried to post this.
I use a rear axle to pull them.
  • barney
  • barney's Avatar
28 Apr 2015 08:23
#669860
I use the rear axle bolt like Rob said with a small ball bearing as previously stated. No extra tools needed
