K1 wire harness
  • jlat
  • jlat's Avatar Topic Author
K1 wire harness
23 Apr 2015 15:54 - 23 Apr 2015 15:59
#669322
hello people; I'm new. Anyone try one of those main harnesses that Z1 ent. sells (out of stock and no time frame when available) and others I've found on e-bay?
Since a stock harness could work for me is there alot of differences between a Z1 and a K1?
Would a Z1 harness be any simpler than a K1?
IBBY
Last edit: 23 Apr 2015 15:59 by jlat.
  • martin_csr
  • martin_csr's Avatar
Re: K1 wire harness
24 Apr 2015 00:44
#669383
A non-stock wiring harness most likely won't be a direct swap unless the part numbers are identical.
if your K1 is an 80s 1000-Ltd, then a Z1 harness is probably quite a bit different.
  • jlat
Re: K1 wire harness
26 Apr 2015 07:47 - 26 Apr 2015 07:47
#669603
hello people and hello martin csr; I see you are real good with wiring as I saw some of your posts in the elec. sec.
I also see a vendor sells a complete Z1 harness. If you where to use that with a K1 engine it should be good? I believe Z1 had points and other than that what could be different? I have a stock K1 harness for a IC igniter iggy and those have alot more wires and wiring for hazard lights. I'll be using a Dyna S . Maybe the gauge plug could be different also.
Any more words?
IBBY
Last edit: 26 Apr 2015 07:47 by jlat.
