regulator/rectifier -stator plug
  • Catfish 58
  • Catfish 58's Avatar Topic Author
16 Apr 2015 20:16 - 16 Apr 2015 20:35
#668312
Hello All: My question is on a 81 kz750 that I have wired bare bones. The plug from the stator to the regulator has a black and a brown wire & of course the 3 yellows. the black seams to be hot/ I thought that it was a ground. please help with what I am missing. I put my voltage tester on it and it reads 38+ when the brown sensor wire is not pluged in and around 12.3 when the brown is pluged to a hot lead. Can someone help me understand whats happening.
Last edit: 16 Apr 2015 20:35 by Catfish 58. Reason: spelling
  • martin_csr
  • martin_csr's Avatar
Re: regulator/rectifier -stator plug
17 Apr 2015 00:30 - 18 Apr 2015 13:02
#668327
Do you have a wiring diagram? For the stock wiring harness the brown wire acts as a sensor wire for the voltage regulator & it is basically a hot wire. The voltage regulator circuitry detects the voltage from the brown wire to determine whether or not to continue charging the battery.
R/R -->> battery -->> Ign Switch -->> brown wire -->> R/R.
Assuming the bike is a 750-4 E or H, there should be 3 yellow wires coming from the stator. The voltage from those wires, testing in pairs, should be about 50 VAC @ 4000 rpms (set meter to AC ---- alternating current). The voltage regulator should also have 3 yellow wires, a black ground wire, a red/white power output wire, & a brown sensor wire. The red/white wire supplies DC voltage to the bike & will be connected to either the starter relay pos lug or the positive battery terminal.
Last edit: 18 Apr 2015 13:02 by martin_csr.
  • Catfish 58
17 Apr 2015 05:49
#668343
Thank you, I understand the brown as a sensor and the 3 yellow wires from the stator. My main question is why is the black wire hot / showing voltage when it should be a ground?
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2015 06:17
#668350
Do you have the red/white wire? The black wire sends excess power to ground. When dealing with these it is critical to disconnect the black wire first.
  • Catfish 58
17 Apr 2015 06:30
#668356
Yes on the red and white. so the black wire is suppose to show voltage?regal ookbmi
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2015 06:33
#668358
Whatever that means. That's the excess voltage going to ground. Do you have a manual?
  • Catfish 58
17 Apr 2015 06:33
#668359
sorry about the letters after. new at this.
  • Catfish 58
17 Apr 2015 06:37
#668360
yes on the manual
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2015 06:37
#668361
Don't switch wires while it's running. Shut it down before testing. Connect the ground last.
  • Catfish 58
17 Apr 2015 06:47
#668363
won't the black wire short out if I hook it to a ground point
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Apr 2015 07:13 - 17 Apr 2015 07:28
#668369
I bought a used reg/rect from The Old Kaw Man two years ago. I had bad connections at the plug and ruined it. I just bought another one last month. He sent me this.
File Attachment:
File Name: reg-rect-r...e1-2.zip
File Size:445 KB
Last edit: 17 Apr 2015 07:28 by SWest.
  • Catfish 58
17 Apr 2015 07:58
#668378
Thanks I will get to the house tonight and give this a try. This helps a bunch, I am still a little worried about the black wire sparking when I touch it to any kind of ground.
