1983 GPZ 1100 Fouling plugs
- kawi810
Re: 1983 GPZ 1100 Fouling plugs
29 Apr 2015 06:34
if you never serviced the throttle position sensor i would take a look at that .they get worn and go out of adjustment.that would cause a rich fuel problem.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- kawi810
29 Apr 2015 06:58
check in the FSM what the procedure is .you check the resistance with a ohm meter.the tps is a carbon film resistor and the carbon wares and gives a false value .the ECM thinks the throttle is open and the injectors supply more fuel causing it to run rich.
29 Apr 2015 07:07
When I was wrenching on bikes in the 80's, Kawasaki was having problems with their EFI bikes. Did they ever solve it? Not too many of them around.
- man-of-war
02 May 2015 05:40kawi810 wrote: check in the FSM what the procedure is .you check the resistance with a ohm meter.the tps is a carbon film resistor and the carbon wares and gives a false value .the ECM thinks the throttle is open and the injectors supply more fuel causing it to run rich.
You might be right . I tried to ear tune the idle using the TPS as Mfolk suggested but will not allow me to turn left or right without the engine stalling.
My plugs look alot better after a HWY riding VS in town riding. I honestly think the TPS needs to be replaced.
ANYONE HAS A SPARE USED ONE FOR SALE.
02 May 2015 05:47
Check your connections on your silicon HT wires at the coils. I used them years ago and went back to solid core wires.
- MFolks
02 May 2015 09:49
If the fuel return valve(in the bottom of the tank, plumbed into the fuel pressure regulator), gets clogged, the engine will run rich.
- kawi810
02 May 2015 10:11
the TPS is hard to find, might check e bay .go to 750 turbo site they have a lot of very intelligent members on there that could help you with this problem .partszilla list the TPS and TEMP sending unit as the same for both bikes.i am having problems with my 750 turbo runs like crap . alot of electronics to deal with.and hard to get replacement parts.
