Ignition switch
  • Robby 77
  • Robby 77's Avatar Topic Author
  • never give up
Ignition switch
06 Apr 2015 07:05
#666761
Hi! everyone got a problem with the ignition switch for no reason in parking he stay lock and very hard to unlock I can only free the lock if I use a long screw driver and push the tongue under the lock so I wonder fit a new one and where I get one or just dismantle the switch and cut out the tongue as it will be risky when riding the bike please let me know if you have an answer to this problem regards Robert
kravi
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Ignition switch
06 Apr 2015 07:08
#666762
Have you tried to lube it?
The following user(s) said Thank You: Robby 77
  • Robby 77
  • never give up
Re: Ignition switch
07 Apr 2015 02:42
#666918
Yes but is okay if I push a little piece of metal witch stick out under the switch then the all steering can move again only to lock itself on the left so anyone with an ideas thank you anyways will try to fix this problem Robert
kravi
