Disassembling Meters
  • ffltstn
  • ffltstn's Avatar Topic Author
02 Apr 2015 19:07
#666326
Both my meters are rusty and the rubber dampers are hard and brittle.
Can they be taken completely apart, easily and safely, So I can sand and paint the housings?
Or should I just tape off and paint?
If I can't find the damper suggestions on what to use in place?
Thanks,
Ken
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Disassembling Meters
02 Apr 2015 19:18
#666330
If they are still working and look good, don't open them. I cut fuel line to use for dampers.
  • TexasKZ
  • TexasKZ's Avatar
02 Apr 2015 21:13
#666344
There is at least one thread on gauge restoration around here. It is not very complicated, but does require a great deal of patience and care.
  • ffltstn
03 Apr 2015 05:59
#666359
I am able to be careful not always patient enough lol. This is what I'm working with, think I'll tape them off and sand and paint. The dampers are about $25 each but I need something to put there so I may have to bite the bullet.
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
  • martin_csr
  • martin_csr's Avatar
03 Apr 2015 06:06 - 08 Apr 2015 02:44
#666360
To open them you have to either cut or un-crimp the clamping ring as it is pressed in place at the factory. wiredgeorge over at wgcarbs may have a how-to w/ pics linked on his site somewhere. Or it may still be here somewhere, perhaps in the archives.
Dampers. mousepad material, maybe weatherstripping insulation from the hardware store.
Z1-Resto
Last edit: 08 Apr 2015 02:44 by martin_csr.
  • ffltstn
03 Apr 2015 06:15
#666361
Ok thanks, I'm not tearing into them that much. I can make them look good just will take more time.
Thanks
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Apr 2015 07:24
#666365
I had to get into mine. Only temperary fix. Put in a new dace plate, stopped the needle from jumping around but now it lies. Will buy new ones.
  • davido
  • davido's Avatar
03 Apr 2015 09:53
#666395
This article worked for me.
This is how they came out
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
03 Apr 2015 13:27
#666422
Hi Ken,
You sent a message that you were having problems posting pictures.
Here's a good discussion about posting pics on KZR:
www.kzrider.com/forum/8-about-the-site/5...posting-pics-is-easy
Good Luck
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • jakedude
  • jakedude's Avatar
03 Apr 2015 14:17
#666431
Nothing lasts, nothing is finished, and nothing is perfect.
  • missionkz
  • missionkz's Avatar
03 Apr 2015 17:10
#666449
I pulled one of my old original speedo instruments apart. Yes, by peeling that rotten seam apart.
I did it to see if the drive inside was acting up (needle bounce of +7mph and -7mph at 55mph to 60mph) and I wanted to replace the inked face, which also had multiple cracks with light shining through at night.....
The seam wasn't bad, just took time.
The hardest part was pulling that damn, SOB speedo needle off the stem.... good God!!! X100.
I could not believe how stuck it was and was shocked I did not destroy the needle trying to pry it off.
I did get it off after a solid 45 mins.... by dismantling the entire drive gear assembly to the odometer and trip OD so I could get under the needle and pry it up using the frame for leverage with two small screw drivers from two sides.
If had the money I would have just bought another speedo.
The cool thing was if I wanted to, I could have set the odometer back to zero with NO effort.
I didn't.....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Apr 2015 17:16
#666450
I used my cheap valve adjusting tool and the screws as a fulcrum. You have to be under the brass bushing so you won't destroy the needle. Third time in for me. I'll just buy new ones and put these on eBay, parts or not working.
The following user(s) said Thank You: missionkz
