cluster lights
  • jtpvg
  • jtpvg's Avatar Topic Author
cluster lights
09 Mar 2015 18:23
#663910
So after sitting all winter I went out to the shop to fire her up. The battery was dead so I went and purchased a new one since this one has gave me 4 faithful years. Well after I put the new one in I noticed my cluster lights came right on. Started the bike and let it idle for awhile. Turn it off and the cluster stays lit. Only way to get it to go off is to unhook the battery. I'm thinking maybe a faulty ignition switch. Any ideas what it could be? Any help is much welcomed....
82 kz 1000 Cafe Racer
82 xj 750
photobucket.com/user/jtpvg/library/82 KZ 1000?sort=3&page=1
  • ewolpert
  • ewolpert's Avatar
Re: cluster lights
13 Mar 2015 06:25
#664306
You are saying all of the indicator lights turn on when you connect the battery, such as turn signal indicator, high beam indicator and so on? I am also assuming this is not typical of the 82 as it is in cars for instance?
Eddie
78 KZ650 b2a
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: cluster lights
13 Mar 2015 11:35
#664335
Check the ignition switch.
The following user(s) said Thank You: jtpvg
  • jtpvg
Re: cluster lights
13 Mar 2015 17:10
#664354
Just the backlight on the cluster comes on. I think maybe a mouse chewed on a wire or something while its been covered in the garage this winter. I'm going to go through it real good this weekend and try and see what the problem is. I'm a good fab guy but not so much on the electrical part. Hopefully it will just be a grounded out wire or something.
82 xj 750
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: cluster lights
13 Mar 2015 18:58
#664361
Do you have a headlight switch?
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
Re: cluster lights
14 Mar 2015 11:21
#664400
swest wrote: Check the ignition switch.
^^^^^^^^^^^^^^^+1
Steves right!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • jtpvg
Re: cluster lights
14 Mar 2015 17:46 - 14 Mar 2015 17:47
#664443
well I was fooling around with it today and I reached under the tank and shook the wires that go under my tank the light went off. If I keep shaking it they'll go off, on, off and so on. I'm thinking it has to be a loose or grounded out wire. The field mice are everywhere out here in the woods of Ky. Tomorrow I will remove my tank and check everything out. It's suppose to be in the 70's monday and I want to ride!!! This winter has been wayyyyyy too long for me. And yes I do have a headlight switch for changing from dims to brights.
82 xj 750
Last edit: 14 Mar 2015 17:47 by jtpvg.
