ignition coil/spark plug set-up help
  • sierralimabravo
  • sierralimabravo's Avatar Topic Author
17 Feb 2015 18:02
#661903
Greetings KZriders, I am an aspiring KZrider. I have a 1980 kz750E i have been trying to get running for over a year. I recently go to the point where I can try to fire it up. After many attempts I wonder if I have the spark plug wires plugged into the correct location on the IC. I think this may be the case because it will fire once occasionally but no consecutive firing. I have looked in my Kawasaki manual, and my clymer manual and I cant find this bit of info. It may be something else, but this is an easy fix to start with. I have compression. I guess there is fuel because of the firing, but I don't know about spark. Any help with spark order would be greatly appreciated.
  • mike1957
  • mike1957's Avatar
Re: ignition coil/spark plug set-up help
17 Feb 2015 18:48
#661906
I was reading your post and found a older post on this site
hope this helps. click on the link below.Mike
www.kzrider.com/forum/4-electrical/40899...k-plug-to-coil-order
mike1957
  • martin_csr
  • martin_csr's Avatar
17 Feb 2015 18:48 - 17 Feb 2015 18:53
#661907
I think the 750E is the same as my 81 650-CSR. 1-2-3-4 L-to-R sitting on the bike.
1-4 spark plug wires -->> right side coil -->> black & red wires from the igniter
2-3 spark plug wires -->> left side coil -->> green & red wires from the igniter
The stock coils may have (+) & (-) embossed into them. Red = (+) & Green/Black = (-)
Here's a site w a pdf manual & wiring diagrams. mbsween.bike-night KZ750L3 page
Scroll down & click "The Bible" link. The pdf isn't the greatest, though.
Note: not applicable to the 750E, but some of the wiring diagrams are mislabeled in the links. The 1981 Ltd is an H2, the 82 is an H3, & the 83 is an H4. search tags mbsween KZ750L3
Last edit: 17 Feb 2015 18:53 by martin_csr.
  • rstnick
  • rstnick's Avatar
17 Feb 2015 19:01 - 17 Feb 2015 19:09
#661912
Welcome.
Here's a wiring diagram that should help.
[IMG
You can try swapping the green and black wires to the coils, and see if she'll start that way.
If the lobe on the mechanical advancer has been installed wrong, it could be 180 degrees off.
Swapping the green and black coil wires will confirm this.
If she still doesn't start, switch the wires back.
Some info on IC Igniter testing;
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 17 Feb 2015 19:09 by rstnick.
  • sierralimabravo
17 Feb 2015 19:09
#661913
That is what I was looking for. Maybe I'll get a chance to check it out in the next couple of days. Thanks.
