Acewell 2853 gauge
- gixxerkidd03
Acewell 2853 gauge
11 Jan 2015 10:26
Just ordered one. Who has one and how do you like it? Any tricks and tips on wiring? There some features like fuel level and engine temp I'm not set up for at the moment. Any suggestion on how I can?
-Eric
-Eric
1981 KZ750e
Re: Acewell 2853 gauge
11 Jan 2015 17:02
Got a pic?
- kaw-a-holic
11 Jan 2015 18:08
Your going to need sending units for both. Not to sure about the fuel level sending unit, I bought a tank lid with one in it. As for temp, all you need is a oil temp sending unit. I'm sure you could find on the same thread as the oil port above your points cover, assuming is a KZ1000. I'm not familiar with the other models.
Here is a link to the speedo Steve.
www.acewell-meter.com/c0_1.php?pid=3&bid=11
Looking at the functions I do not see a oil temp indicator just an oil pressure indicator which is propably what you have now.
FUNCTIONS & SPECIFICATIONS
FUNCTIONS SYMBLE SPECIFICATIONS
Bar graphic speed meter 12,000 rpm
Digital Tachometer & Warning RPM 100-19,900 rpm, 100rpm increment
Speed Meter 2.4-300 km/h (187.5 M/H)
Trip Meter 0.00-9999.99 KM/Miles
Odometer 0.0 - 99999.9 KM, 0.0-62499.9 Miles
Maximum Speed MAX 2.4-300.0 KM/h (187.5 M/h),
Average Speed AVG 2.4-300.0 KM/h (187.5 M/h),
12/24 Hour Clock 0:00’00” – 11H59’59”/23H59’59”
Riding Timer RT 0-99H59`59``
Total Riding Timer 0-9999H59’,
Power Input DC 12V
Speed Sensor Reed Switch & Magnet
Tachometer input CDI or Sparking Plug signal
Wheel circumference setting 1mm-3999mm (1mm increment)
Dimensions Φ64mm x 40 mm
Power Input DC 12V
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- jeffw
20 Jan 2015 09:07
I used one on my 650 dime city cycles provide a plug n play setup for the speedo
www.dimecitycycles.com/vintage-cafe-race...awasaki-ace-s10.html
As for gas guage not sure didn't use it and the tacho required the inline resistor that is provided to properly pick up the tach.
1977 KZ650 B1 "Cafed"
4-1 & Pods, Electronic Ig. & Dyna Coils
forums.kz650.info/index.php?topic=9020.0 - SOLD :(
1982 KZ1100 A2 Stripper
kzrider.com/forum/11-projects/596850-198...100-a2-shaft-project
