Electrical problem post burying wires
Re: Electrical problem post burying wires
21 Dec 2014 03:23!Seymore wrote: Why do we have 2 threads for one problem? Can a Mod/Admin consider combining them? Thanks...
kzrider.com/forum/5-chassis/596730-repla...stock-bars-with-what
kzrider.com/forum/4-electrical/596751-el...m-post-burying-wires
Posts about wire burying have been moved from the chassis forum topic to the electrical forum topic.
The following user(s) said Thank You: !Seymore
Re: Replacing stock bars with what?
21 Dec 2014 06:21 - 21 Dec 2014 16:30
my mistake. never mind. :blush:
Last edit: 21 Dec 2014 16:30 by martin_csr.
- Britome
Re: Re:Electrical problem post burying wires
21 Dec 2014 15:00
So before i pulled the wires out from the bars, I tested each wire where it connects to the housing and then the other end. All wires are giving me a beep on the multimeter. Are you sure I need to pull them out and reinsulate/shield. If that was the problem then they wouldn't test out. Right?
- Britome
21 Dec 2014 15:13
I just pulled out and reinspected. No insulation is broken on individual wires.
- !Seymore
- Ride on...
21 Dec 2014 15:56
A 2nd layer of insulation will never hurt, So, did you test impedance between the wires and the bar? ...not continuity, while the wires were in the bars?
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
- Britome
22 Dec 2014 10:06
Hmmm. I did not. I'll just shrink wrap them and put Em through
- Britome
10 Jan 2015 07:42
Everything is shrinked and tucked away. All works except hazards (not sure if they ever worked) and the headlight. I tested the headlight and it is good. I think my best bet is to run new wiring from the light to the battery. I don't care about switching from hi to low beams.
Any advice as to how to enable it to be switched so that it shuts off when not running?
10 Jan 2015 08:44
You may want to think twice about not having high and low beams; eliminating the ability to switch could get you hurt. Here's why - Years ago I was riding along a twisty country road on a very dark night; I had my high beam on. The high beam filament in the bulb broke and pooof - INSTANT darkness! I immediately switched to low beam and all was good. If I hadn't been able to switch to low beam I definitely would have gone off the road before I could stop. Ed
- Britome
11 Jan 2015 06:56
Ok. And how where in the harness do you recommend I tap in?
11 Jan 2015 07:14 - 11 Jan 2015 07:15Britome wrote: Ok. And how where in the harness do you recommend I tap in?
Tap in for what?
Sometimes an accessory connector may be available from the stock wiring harness.
And may appear on the wiring diagram.
The accessory connector may be the female half of a bullet connector.
And usually intended to furnish battery-positive voltage when the ignition switch is turned ON). Aka switched battery positive, which may be abbreviated to something such as Switchd.batt+,
The female connector might be underneath a side cover, or underneath the fuel tank, or inside the headlight shell.
Last edit: 11 Jan 2015 07:15 by Patton.
