Wiring Questions
  • conman846
  • conman846's Avatar Topic Author
Wiring Questions
11 Dec 2014 11:54 - 11 Dec 2014 11:55
#655849
I have a question about some wires I can't identify.
I purchased a new wiring harness,since the one that came with the bike was beyond repair. The guy I bought it from said it came from a 1982 kz550-c.
I have two questions: First, there is a green and pink wire that I can't identify. Every wiring diagram I've looked at it doesn't seem to show up. My guess is its the neutral light indicator?
Secondly, what does the brown and orange connector go to?
Attachment lightsquestion.jpg not found
I circled the 2 areas in the attached picture. I should note that the all the loose wires came in a 9 pin connector, however I removed the connector to try and sort the wires.
Thanks for any help
Last edit: 11 Dec 2014 11:55 by conman846.
Re: Wiring Questions
11 Dec 2014 13:30
#655853
Here are links to the C1 and C3 wiring diagrams in KZr's FILEBASE, which may help determine which colors go where.
www.kzrider.com/filebase/search/finish/1-general/281-z550c3
www.kzrider.com/filebase/search/finish/1-general/276-z550c1
Good Fortune! :)
  • floivanus
  • floivanus's Avatar
11 Dec 2014 13:32
#655856
Brown/ orange is one of the flashers i believe
Past; 78 kz1000, 83 kz550
Andrew
