.82kz750n1,
- muffinsmannkz750n
- Banned
.82kz750n1,
25 Nov 2014 09:19
..after changing starter solenoid , >had starter motor wire connected on same post as positive battery..would try and turn over as i put ground connect on battery...now i get nothing with everything in place..nothing no light no click,click of solenoid..not a damn thing ..help...
- Tyrell Corp
Re: .82kz750n1,
25 Nov 2014 12:51
check your fuses first.
- pete greek1
Re: .82kz750n1,
25 Nov 2014 13:05
Also check the ground wire from the battery to the frame or motor , wherever it's connected to, be sure it's rust & corrosion free, & that it is tight
Pete
Pete
