Correct spark plug 1976 KZ750B
  • Steve AZ
  • Steve AZ's Avatar Topic Author
24 Nov 2014 06:58
#654499
So, at the beginning of the original service manual in the specification section, it calls for a B6ES spark plug, but in another section on page 181 where it explains why plugs are hot and cold, it calls for a B8ES for normal riding. What s the right plug for this bike? I use pod filters and a 2into1 pipe if that makes any difference. Thanks
Phoenix, Az
1976 KZ750B1
1994 Moto Guzzi California 1100i
1971 Moto Guzzi ElDorado 850
  • MFolks
  • MFolks's Avatar
Re: Correct spark plug 1976 KZ750B
24 Nov 2014 11:51
#654521
A B6ES is a fairly hot plug, and a B7ES is a little colder. You'll need to check the sparkplugs to determine what the engine needs for proper combustion. And the Ethanol in todays gasoline, makes it hard to determine that.
  • bountyhunter
  • bountyhunter's Avatar
24 Nov 2014 12:55 - 24 Nov 2014 13:06
#654526
Steve AZ wrote: So, at the beginning of the original service manual in the specification section, it calls for a B6ES spark plug, but in another section on page 181 where it explains why plugs are hot and cold, it calls for a B8ES for normal riding. What s the right plug for this bike? I use pod filters and a 2into1 pipe if that makes any difference. Thanks
I think the B6ES is the correct plug for "combined" riding (city stop and go and expressway). If you ride only on the freeway, I think B7ES might be better but B6ES is definitely the plug specified in the FSM for the 750 twin for general usage. I have always run B6ES (35 years).
Last edit: 24 Nov 2014 13:06 by bountyhunter.
  • bountyhunter
24 Nov 2014 13:05
#654528
My FSM says this about the plugs:
