Biggest Highest Amp. Battery ???
- loudhvx
Re: Biggest Highest Amp. Battery ???
13 Nov 2014 08:54 - 13 Nov 2014 09:02
This one:
www.batterystuff.com/powersports-batteries/sYT12C.html
CCA 140. 12 amp hour.
But it's for a 550. I don't think a 1000 could get by with it.
Here's what they show for the 77 1000:
www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
$66.
The technical specs are on the right side of the page, with physical dimensions. CCA 210. 14 amp hour.
Length 5 5/16
Width 3 9/16
Height 6 3/8
Weight 10.6
Shipping Weight (lb.) 11
DC Output Voltage 12V
Amp/Hr 14
C.C.A. 210
OEM Ref YB14L-A2/YTX14AHL-BS
Charged Ready to Install
Manufacturer: Scorpion
Made In: Asia
$66.
Length 5 5/16
Width 3 9/16
Height 6 3/8
Weight 10.6
Amp/Hr 14
C.C.A. 210
Made In: Asia
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 13 Nov 2014 09:02 by loudhvx.
- kzdcw
- 77' KZ1000A
13 Nov 2014 15:24 - 13 Nov 2014 15:25
That's the one that Bountyhunter is using. Must be working okay for him. I'm going to continue looking for a bigger, higher Amperage battery that will fit in my battery box. May be overkill, but don't think it would hurt. Anymore input is greatly appreciated as with prior.
77' KZ1000A
Last edit: 13 Nov 2014 15:25 by kzdcw.
- bountyhunter
13 Nov 2014 16:40 - 13 Nov 2014 16:43I'd rate it better than OK. It's over a year old and still spins the starter very fast like I had only seen brand new batteries do. It is without doubt the best lead acid battery I have ever had in the bike in the 35 years I have had it.kzdcw wrote: That's the one that Bountyhunter is using. Must be working okay for him. I'm going to continue looking for a bigger, higher Amperage battery that will fit in my battery box. May be overkill, but don't think it would hurt. Anymore input is greatly appreciated as with prior.
If you are concerned about CCA and starting power, the best move is to modify the electricals so that there is a relay that disconnects the lights and accessories when the starter relay energizes. That greatly lowers the CCA needed when starting and increases battery life significantly. That's a lot easier and cheaper than buying a super sized battery.
Last edit: 13 Nov 2014 16:43 by bountyhunter.
- kzdcw
- 77' KZ1000A
13 Nov 2014 17:52 - 13 Nov 2014 18:12
Bountyhunter, On this 77' Model, when turning on ignition switch, nothing is on ( lights,signals, etc. ) so I don't see why more CCA's would be needed? I don't know how a relay would affect it or even how to wire it in if it did? So if your able to provide more clarification on how, that would be appreciated !!!
77' KZ1000A
Last edit: 13 Nov 2014 18:12 by kzdcw.
13 Nov 2014 19:23
kzdcw
You don't need a relay to shut off the headlight. The 1977 models had the ON/OFF switch for the headlight. Later models had the headlight come on whenever you turn on the ignition key. Ed
- kzdcw
- 77' KZ1000A
13 Nov 2014 20:08
Ed, That's kind of what I thought-Thanks.
Just have to sit down for a minute and take some measurements to find a Higher CCA battery.
77' KZ1000A
- Tyrell Corp
13 Nov 2014 20:34
The Gel batteries seem to havve a higher open circuit voltage and amp hour rating, bit early to say what the life expectancy is as Ive only had it about a year.
I wouldn't go too overboard on this quest for amp hours rating and cold cranking capacity: the 550/750 were 12 amp hour, the 100/1100 14 amp hour and even the mighty z1300/6 only 16 Ah.
Even running high compression and bored out it seems the starter clutches not the battery are the weak point. If you are really keen maybe go up slightly to heavier gauge earth strap and battery to solenoid to stater leads.
I've cold started these at below freezing 0 degrees celcius before and no problems.
- bountyhunter
13 Nov 2014 22:04 - 13 Nov 2014 22:04OK, if yours doesn't have lights on all the time you're lucky. US bikes after about 78 all have the lights hard wired on with the ignition switch. You can't turn them off and it makes it hard on the battery.kzdcw wrote: Bountyhunter, On this 77' Model, when turning on ignition switch, nothing is on ( lights,signals, etc. ) so I don't see why more CCA's would be needed? I don't know how a relay would affect it or even how to wire it in if it did? So if your able to provide more clarification on how, that would be appreciated !!!
Last edit: 13 Nov 2014 22:04 by bountyhunter.
- KZJOE900
- Administrator
Super Users
18 Nov 2014 14:08bountyhunter wrote:The lithium batteries claim higher CCA rating. However, reviews are mixed. They either work great or die quickly and often.kzdcw wrote: I looked at that one, but would like one with Higher CCA ?
www.batterystuff.com/batteries/lithium-i...es/sstx14ahq-fp.html
I wonder if this battery can be used in the KZ900. They recommend a different batter for it with only 170 CCA as opposed to 210 CCA on this one. Looks like It can fit. Has anybody tried it?
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- inline79
10 Dec 2014 11:32
AGM is the way to go. virtually all are made in China, so stick with a reputable dealer or one with good reviews as quality varies widely.
Lithium is pretty heat and voltage sensitive so I'm not sure if they are really suitable for typical classic motorcycle usage yet...
10 Dec 2014 12:46
I've been using High Tech. Battery Solutions. They sent me a battery for a KZ 900 when I needed one for a Z1. It was much smaller and with all my lights, too small. I called them and they sent me the right one for $5 extra free shipping. So I guess I got mine for under $40 with a 1 year warranty. I sold to other on on CL for $25 as they didn't want it back after I filled it up with acid. I have referred them to my friends.
