reserve lighting system
  • saxjonz
  • saxjonz's Avatar Topic Author
  • KawboyZ
25 Oct 2014 14:12
#651691
What does it do? Would it affect the bike running? I have an 80 LTD 1000 that I recently made a mistake of hooking a turn signal lead to the little blue and green wire. I popped a fuse which I replaced and now bike won't start. Light comes on headlight dimly and if I am not mistaken I think that on the 80 model it shouldn't come on till after bike starts.
I am fairly close to getting this old girl back on the road and then I experienced a brain fart. Wow, can't believe that was such a rooky move.
79 LTD B3
  • saxjonz
  • KawboyZ
Re: Re:Re: reserve lighting system
25 Oct 2014 21:31
#651735
Was thinking it was this thing. When I pull plug wires and hold them off of the plug there is strong spark and bike seems like it wants to start until I put wire back on.
I have both spark and gas. I'm stumped. Would plugs go bad from that quick short or what?
79 LTD B3
  • saxjonz
  • KawboyZ
Re: Re:reserve lighting system
26 Oct 2014 07:39
#651752
No one?
79 LTD B3
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Oct 2014 07:51
#651755
Disconnect it and try it again.
26 Oct 2014 09:35
#651761
saxjonz wrote: What does it do? Would it affect the bike running?....
reserve lighting system --
What does it do?
If a filament in a headlight bulb and/or rear bulb burns out, the reserve lighting system activates the other filament so the light(s) will stay on.
When the dim headlight filament burns out, the shift to bright filament is with reduced voltage to help avoid blinding oncoming traffic.
Would it affect the bike running? -- a deactivated reserve lighting system should not affect the bike running.
Would not expect a wiring "short" of any kind to make the spark plugs go bad.
Would service and charge the battery overnight, and then compare voltage being received at the coils' primary terminals to voltage across the battery posts (should ideally be the same or substantially the same).
Would load-test the battery or have it load-tested at any place that sells or services batteries (AutoZone, WalMart, automotive repair shop, etc.).
It's likely that no damage was done simply by blowing the fuse, as that's what fuses are for.
With a good fully charged battery, and full voltage at both coil primary terminals, would remove the plugs, ground them against the engine head, and watch the spark quality while spinning over the engine. Look for fat blue sparks (not wimpy orange sparks).
Condition of plugs, plug wires and caps should also be considered.
Good Fortune! :)
  • zukdave
  • zukdave's Avatar
26 Oct 2014 12:56
#651776
Just unplug it and plug the harness connector's together
that's all it take's to remove it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • saxjonz
  • KawboyZ
26 Oct 2014 18:39
#651817
Patton, thanks, I appreciate the info. Everything is new, plugs, wires, engine rebuild, carbs. Bike hasn't been ridden yet. Have to assemble a few more things yet. I hope nothing was damaged. I will try disconnecting and see if it starts. Bike was running great till I hooked up turn signals wrong. Battery is brand new and fully charged.
79 LTD B3
26 Oct 2014 20:00
#651823
Perhaps unrelated, but if not already done, would assure integrity of the ground connection where the negative battery cable attaches to rear of engine.
Fat blue sparks?
Good Fortune! :)
  • saxjonz
  • KawboyZ
27 Oct 2014 20:28
#651952
STRONG spark. On an unrelated note, I was tiling my kitchen and we took exhaust fan off to tile up. Upon replacing I didn't bother to turn power off. I had wife hold it up while I wired it. Now that was a fat charge that got both of us. I'm pretty sure if I grounded myself on that spark from the bike I would have felt a much stronger shock.
79 LTD B3
