New coil packs
- koloj
New coil packs
25 Sep 2014 06:03
Sorry I post so much.. Thanks for the patience... But I just got two new 3.0 ohm dyna coil packs from z1 the green ones for my 1980 kz750 h1 four cylinder because cylinder 2 wasn't firing... It will idle and Rev in neutral but under load it will studder and backfire one either cylinder 1 or 2 more of like a pop...is this something I missed when installing them new plugs and wires as well.. I thought I was making head way now this.. Thanks
- MFolks
Re: New coil packs
25 Sep 2014 09:12
Did you also replace the sparkplug caps? They don't age well, and can become intermittent.
- koloj
Re: Re:New coil packs
25 Sep 2014 21:48
Found what is was thanks for the input though the main jet holders were Bent cause person had it before me must tighten then to hard
- koloj
25 Sep 2014 21:50
So the needle was one not sitting fully down also Bent so curvy the three holes on the side were closed
