KZ650 F1 1980 Regulator Part Number Help
  • leha730
  • leha730's Avatar Topic Author
22 Sep 2014 14:30
#648368
Hello Everyone.
I am having a problem with a charging system on my 1980 KZ650 F1. Stator and Regulator did not pass an electrical tests. I am looking for original Kawasaki Part number for the Voltage Regulator/Rectifier. The part number starts with 21066.... The regulator that i pulled out from the bike, is "Shindengen SH222-12". Please Help
Thank you
1981 KZ1100 A1
Re: KZ650 F1 1980 Regulator Part Number Help
22 Sep 2014 14:43
#648370
Welcome aboard! According to Kawasaki.com the part number is 21066-1014 (see image below). They are no longer available from Kawasaki, but when they were available the list price was more than $335. Here's a place that has a new old stock one for $175. www.nwvintagecycleparts.com/search-resul...arch.x=8&search.y=14 I have bought from them before and was very pleased. Ed
Attachment 00003b_2014-09-22.jpg not found
The following user(s) said Thank You: leha730
  • martin_csr
  • martin_csr's Avatar
22 Sep 2014 14:44
#648371
Kawasaki.com & Partziilla have the part numbers. From Kawasaki.com:
1980 KZ650-F1 --- REGULATOR,VOLTAGE --- 21066-1014.
Model (27):
KLT200-A1 (KLT200) (1981)
KLT200-A2 (KLT200) (1981)
KLT200-A3 (KLT200) (1982)
KLT200-A4 (KLT200) (1983)
KLT200-A4A (Duckster) (1983)
KLT200-B1 (KLT200) (1983)
KLT200-C1 (KLT200) (1983)
KLT250-A1 (KLT250) (1982)
KLT250-A2 (KLT250) (1983)
KLT250-C1 (Prairie) (1983)
KZ250-D1 (KZ250) (1980)
KZ250-D2 (CSR) (1981)
KZ250-L1 (CSR Belt) (1982)
KZ440-A1 (LTD) (1980)
KZ440-A2 (LTD) (1981)
KZ440-A3 (LTD) (1982)
KZ440-B1 (1980)
KZ440-B2 (1981)
KZ440-D1 (LTD Belt) (1980)
KZ440-D2 (LTD Belt) (1981)
KZ440-D3 (LTD Belt) (1981)
KZ440-D4 (LTD Belt) (1982)
KZ440-G1 (1982)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ750-G1 (LTD II) (1980)
KZ750-M1 (CSR Twin) (1982)
  • martin_csr
22 Sep 2014 14:46 - 22 Sep 2014 14:51
#648372
No eBay APP ID and/or Cert ID defined in Kunena configurationThis one might work. Or search eebbaayy for 1980 KZ650 voltage regulator.
I guess your 650 has a single phase charging system???
Last edit: 22 Sep 2014 14:51 by martin_csr.
  • leha730
24 Sep 2014 12:52
#648644
Thank you very much martin_csr. I looked up the part number with Rick's Motorsports and they manufacture an aftermarket new Regulator for my bike. thanks for the links.
1981 KZ1100 A1
24 Sep 2014 13:04 - 25 Sep 2014 06:17
#648645
Be VERY careful about what you buy from Rick's. They do no always know which parts go with which bikes, and they sell "Universal" stuff that may not be compatible with your bike. Try these folks:
www.oregonmotorcycleparts.com/Products.html
Last edit: 25 Sep 2014 06:17 by 650ed.
  • leha730
24 Sep 2014 20:26
#648703
Thanks for the warning 650ed. After lots of calls and research, i found a yard in Upstate NY, that has the original Japanese part from a running bike for $30 shipping included. This guy came recommended as honest and knowledgeable man . I think I will try him. for 30 bucks, its worth a try.
Thanks
1981 KZ1100 A1
  • martin_csr
25 Sep 2014 06:02 - 25 Sep 2014 06:02
#648735
If buying used, I would check to see if there are any modern bikes w a similar charging system.
My 81 650 is 3-phase & I installed a reg-rec from a 2007 Ninja 500 ($25)(credit to loudhvx). :)
The part is virtually identical to the old stock unit.
Last edit: 25 Sep 2014 06:02 by martin_csr.
