elec tach + Dyna S ignition
- fitscott
22 Sep 2014 05:30
Has anyone installed a Dyna S ignition on a bike that has an electronic tach and if so how did you get the tach to work? Thank you, Scott
The following user(s) said Thank You: MFolks
- MFolks
Re: elec tach + Dyna S ignition
22 Sep 2014 09:35
What make of tach do you have? The Kawasaki tach that is also a voltmeter, has a power source on either the right of left ignition coil.
- 4TheKZ1000
22 Sep 2014 10:59 - 22 Sep 2014 11:04
No eBay APP ID and/or Cert ID defined in Kunena configurationHere is how I made it work: DYNA TACH ADAPTER
the two eye connectors go to coils and the one end connector goes to the tach signal wire
Attachment IMG_23081280x853.jpg not found
Last edit: 22 Sep 2014 11:04 by 4TheKZ1000.
- fitscott
22 Sep 2014 14:53
Thank you for the replies - I should have stated that this application is on a 2005 KZ1000 P24 with a stock Tach and green Dyna 3 ohm coils
