Handle bar switch question.
  • kzmarvo
  • kzmarvo's Avatar Topic Author
05 Jul 2006 20:57
#59587
Will a 750 kz handle bar switch for the start and kill switch fit a 1977 kz900?
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
  • kzmarvo
Re: Handle bar switch question.
05 Jul 2006 22:35
#59595
:unsure:
  • Pterosaur
  • Pterosaur's Avatar
05 Jul 2006 23:44
#59596
Not sure.
There's two issues: handlebar diameter and wire leads from the harness.
If the handlebars are the same diameter (which I think they are) and there's fittings to match wire lead/function between the switchblock and harness (which should be fairly similar, I'd think), I don't see any big issues in using one.
  • trippivot
  • trippivot's Avatar
06 Jul 2006 05:08
#59613
the housing will fit 7/8" bars. the switches will work if hooked up right. the throttle cable is a detail you will have to give attention too
  • wiredgeorge
  • wiredgeorge's Avatar
06 Jul 2006 06:12
#59621
KZ900 has a switch for the headlight on its switchgear. ON PO OFF - There are a number of hot wires coming off... there is a blue wire for emergency lighting system off the ON or PO (can't recall from memory) and a RED wire coming off for the tail light in ON position. If your KZ750 (you didn't bother give any details so the answer will be vague) DOES NOT have a way to shut off the headlight, its tail light wire will come directly off the ignition switch. When you turn the switch to on, the red wire will be one of the ones that has voltage on it. If this is the case, you will need to splice the existing tail light wire (RED) to the wire off the KZ900 red wire off the switchgear. Like I said, the brown and blue wires off the KZ900 switchgear are also hot and the blue loops over and provides power for the headlights and the brown provides power for the horn and other accessories. If you start swapping switchgear, it is easiest to do if the bikes have identical functions like the auxilary flashing unit it present on both and both have clutch interlocks and both have the same functions for the headlight either on all the time or an ON PO OFF switch. If not, you will have to do some figuring.
