Battery advice please...
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
17 Sep 2014 12:29
#647862
:unsure: The old battery on the bike is an AGM, and I'm thinking of purchasing a TruGel to replace it with. I'd like to read a few opinions here first, before making a final decision.
The TruGel is going to cost about $100-$110 shipped, and that is what my new-battery budget is. Any better ideas?
Fire away!
1982 KZ1100-A2/1170 sleeper πŸ˜€
  • HBKwaka
  • HBKwaka's Avatar
Re: Battery advice please...
17 Sep 2014 14:09
#647868
I went to NAPA.
  • bountyhunter
  • bountyhunter's Avatar
17 Sep 2014 17:33
#647885
daveo wrote: :unsure: The old battery on the bike is an AGM, and I'm thinking of purchasing a TruGel to replace it with. I'd like to read a few opinions here first, before making a final decision.
AGM is the way to go. Mine cost $66
www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
  • eddiem
  • eddiem's Avatar
  • KZR FLAG RELAY CARRIER #63
17 Sep 2014 18:13
#647890
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
  • Nessism
  • Nessism's Avatar
  • martin_csr
  • martin_csr's Avatar
18 Sep 2014 07:48
#647940
daveo wrote: :unsure: The old battery on the bike is an AGM, ....
What AGM battery was it & how long did it last?
If longevity was a problem, did it receive proper service? Thanks.
  • dkoz
  • dkoz's Avatar
18 Sep 2014 08:18
#647947
Agm.
Taking inside in the winter trickle charge. Last a long time.
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
  • daveo
  • Premium Member
  • Premium Member
18 Sep 2014 08:49 - 28 Sep 2014 07:57
#647950
Adventure Power...a good battery, but constant use on the bike while the electrical system wasn't charging properly took a toll over a year and a half. It still works and holds a charge, but has lost its resilience, I believe.
Last edit: 28 Sep 2014 07:57 by daveo.
  • inline79
  • inline79's Avatar
24 Sep 2014 12:35
#648643
You can't put a GEL in these bikes unless you can adjust your regulator voltage down to compensate for the lower charge voltage on the GEL batteries.
I like AGM batteries so I can lose the drain hose and not worry about acid all over the place. They cost a bit more, but branding doesn't really matter because virtually all the brands mentioned above source their batteries from a handful of factories in China. Unlike flooded batteries, variability in AGM batteries makes a difference as I've seen crappy ones with cheap vents die in a very short amount of time.
Just remember to keep them topped up over the coming winter. Charge every month, or get a Battery Tender. If it's a trickle charger make sure the float voltage is low enough to not dry the battery out, usually about 13.5V.
Interstate usually has good product. in Canada I deal with cdnrg.com
  • Tyrell Corp
  • Tyrell Corp's Avatar
24 Sep 2014 18:37
#648686
Really? got one on mine and I like the improvement, but only a few hundred miles in a few months is too early to tell.
  • inline79
  • inline79's Avatar
25 Sep 2014 14:17
#648813
Ah wait, i stand corrected... because the Bikemaster "TruGel"... is NOT actually a Gel battery!
para 2:
"So, what is a TruGel battery? What most folks don’t know is...It is an ADVANCED AGM battery!"
www.bikebandit.com/assets/digital_assets...BatteryFactSheet.pdf
  • steell
  • steell's Avatar
27 Sep 2014 21:17
#648992
Get a LiFePo (Lithium Iron)_battery and just ignore it over the winter. Three years and counting on the one in my 750 twin. It only gets ridden a couple times a year and has not seen any kind of charger since I installed the new battery.
