Turn signals
  • Newguy 250CSR
  • Newguy 250CSR's Avatar Topic Author
Turn signals
15 Sep 2014 08:41 - 15 Sep 2014 08:42
#647603
Turn signals are simply not working*. Where do I start?
*1981 Kz 250 CSR, the classic lollipops.
Last edit: 15 Sep 2014 08:42 by Newguy 250CSR.
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
Re: Turn signals
15 Sep 2014 09:16
#647604
Describe more in detail. Fusebox? Flasher? Control corroded? Can't really answer.without more info.When's last time they worked?
79 LTD B3
  • Newguy 250CSR
Re: Turn signals
15 Sep 2014 10:09
#647629
They worked for a NY minute after I got the bike started for the first time in a year+. Then they crapped-out. New bulbs, but I'll have to check the fuses when I get back to the shop.
  • MFolks
  • MFolks's Avatar
Re: Turn signals
15 Sep 2014 15:06
#647663
And the turn signal switch, may have a failed solder joint(happening to the older bikes),or corrosion in the switch contacts.
