Kawa gpz 1100 1984-no spark...Help
  • Why
  • Why's Avatar Topic Author
08 Sep 2014 04:34
#646658
Hi there... Ive got a kz as mentioned... I was out driving, got home and parked it just as normal...since the day after, it never would start again....My main computer or the Box in the rear, gives me a fault yhat says: no ignition pulse is present, and i either got no spark what so ever... Plizz help... I have so far messuered more or less the all Components to be fine, but still...no spark.....
  • KzJim
  • KzJim's Avatar
Re: Kawa gpz 1100 1984-no spark...Help
08 Sep 2014 11:52
#646710
Why wrote: ...no ignition pulse is present.....
The pickup is bad. I had this issue with my katana, the pulser pickup tested fine as described in the manual, but wasn't producing the trigger... replace the pulser and I bet you will get spark.
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
