kick start onley
- vulcanizer
kick start onley
07 Sep 2014 07:09
Is it possible to make my 78 kz1000 a kick start onley bike? If so how do i do it?
jeff macbeth
Re: kick start onley
07 Sep 2014 07:58 - 07 Sep 2014 14:44
Um, only use the kick starter? :blush:
.... If the bike doesn't have a headlight ON/OFF switch, I would add one, so that you can turn off the headlight when starting. New, good battery.
Make sure there's good compression and the valve clearances are checked & within spec.
Kick starter or not, I would go through the bike methodically w a fine toothed comb to make sure everything is working right, checked & set as per the factory manual: good battery & the charging system is working correctly; the fuel system is clean & in good working order; the ignition system is good. A lot of that stuff is easy & hopefully most of it will already be spot on. Check one thing, double check your work, then move on to the next.
Last edit: 07 Sep 2014 14:44 by martin_csr.
