KZ650-B1 Wiring diagram
  • Twilightoptics
  • Twilightoptics's Avatar Topic Author
06 Sep 2014 19:02
#646497
Seem to be having difficulties locating a wiring diagram for my bike. '77 KZ650 B-1. I had a coil wire die so I put Dyna green 3ohm coils on to go with the Dyna S ignition I already had. After 30seconds of run time, the main fuse blew. It's got a mere 1.5ohms to ground now. Blows instantly, but only at key on.
The FSM I have is a reprint and the wiring diagram is too blurry.
Thanks,
-Paul
1977 KZ650-B1
Re: KZ650-B1 Wiring diagram
06 Sep 2014 19:13
#646502
  • JR
  • JR's Avatar
06 Sep 2014 19:16
#646503
Looks like there is one in the Filebase here. Look up top. Put the cursor on FILEBASE, click on SEARCH and enter KZ650 in the box
  • Twilightoptics
06 Sep 2014 19:17
#646506
Sweet! That should get my going. It blows with the run switch off, and I have the coils on a relay so it shouldn't be too tough to track down. Just tedious.
Thanks Ed!
PS I tried the one in the filebase. It downloaded but loads blank.
1977 KZ650-B1
  • Twilightoptics
07 Sep 2014 15:49
#646606
Traced it out to the horn. I must have moved it just enough running plug wires and such, to ground the brown wire lead onto the frame.
All good now! Onto the fork seals!
Thanks,
-P
1977 KZ650-B1
07 Sep 2014 16:59
#646619
If you run into any issues with the fork seal be sure to ask before getting into trouble. Ed
  • Twilightoptics
14 Sep 2014 14:17
#647509
Thanks Ed! I've already built the tool as you described in another thread for holding the inner assembly. Came apart easy. I Cleaned the forks up and will paint/reassemble this week.
1977 KZ650-B1
14 Sep 2014 14:55
#647518
Glad to hear it worked well. :) Ed
