i know this is wrong wiring
  • hollywood86
  • hollywood86's Avatar Topic Author
  • Shit Happens
04 Sep 2014 10:20
#646234
hay guys so finally had time to really look through my wiring. thanx to the reading ive been doing ion this site i noticed my regulator rectifier has a green and red wire coming from it aside from 3 white(78 kz650 D) and noticed this . i guess the PO ran out of red wiring and ran a black wire from it and forgot about it and connected both green and red wires together to ground. if im not mistaken red is normally power? should i leave the green on ground and connect red to power?
[IMG
[IMG
HOLLYWOOD
1978 KZ650 D1A
  • loudhvx
  • loudhvx's Avatar
Re: i know this is wrong wiring
04 Sep 2014 11:42 - 04 Sep 2014 11:43
#646246
Depends.
If it's from a Honda, the black is likely switched hot. Red would be output to battery. Green ground.
If it's aftermarket for a Kaw, the red would still be output to battery, but green is usually positive output to the field coil (which your bike does not have, so it would be the wrong type regulator) and black is ground.
Do you feel lucky? :unsure:
Last edit: 04 Sep 2014 11:43 by loudhvx.
  • hollywood86
  • Shit Happens
05 Sep 2014 09:01
#646336
thanx for that i was not feeling lucky at all soo i hooked up red wire to positive and green to negative checked the charging system and worked. thanx again battery is charging now.
HOLLYWOOD
1978 KZ650 D1A
