MSD 3.0 Ohm Coils?
- kzdcw
- 77' KZ1000A
MSD 3.0 Ohm Coils?
04 Sep 2014 05:58
I have a 77' KZ1000A long term project to get running again. Still has stock points. Have a chance to purchase a set of MSD 3.0 Red Coils for it for a reasonable price.
Everyone here seems to used the Dyna 3.0 Green Coils.
Will these MSD coils work and are they relatively easy to mount/install on the bike? Not familiar with them at all?
77' KZ1000A
- loudhvx
Re: MSD 3.0 Ohm Coils?
04 Sep 2014 07:37 - 04 Sep 2014 07:39
Are you sticking with points for a long time?
The lower resistance of the 3 ohm coils will increase the current on the points which will reduce their service life. People use the Dyna 3 ohm coils for use with a Dyna S ignition, or even the factory electronic ignition.
The original points coils were 4 ohms.
Z1enterprises sells the 4 ohm coils for about $40 each, last i checked.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 04 Sep 2014 07:39 by loudhvx.
- kzdcw
- 77' KZ1000A
04 Sep 2014 09:57
Didn't know but learning. Plan on using points for a while. Bike is still in the process of being totally rebuilt and hasn't ran in over 20 years!
I really don't even know if the stock coils are even good as well as the plug wires. Just assessing everything as I go.
Like to upgrade to electronic ignition at a later time and better coils.
Having not being familiar with MSD coils at all, My main concern was if they work and fit? They appear to be bigger and have different mounts than the Dyna or Factory coils?
77' KZ1000A
- loudhvx
04 Sep 2014 11:53 - 04 Sep 2014 12:00
Call Z1 to confirm they will fit your frame, but I think they should.
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
$36 each. Not bad. Plus you get wires with them. You just need new caps.
These coils are meant for points, and will work with a Dyna S electronic ignition, (the most popular aftermarket ignition for these bikes), so you won't have to buy new coils if you get a Dyna S.
Unfortunately, they are out of stock... probably because they are so popular... so you should call them to order them to see what the lead time is. I think they've been out for a while.
Next best option for points (and will work on the Dyna S) would be the 5-ohm Dyna Coils.
Sorry, don't have any info on the MSD coils, but you wouldn't want them for points anyway. If you upgrade to the Dyna S now, then you might want them.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 04 Sep 2014 12:00 by loudhvx.
- bountyhunter
04 Sep 2014 13:01
Would not use a 3 Ohm coil with points unless you add a ballast resistor to reduce the current a bit. Power in the 3 Ohm coil is really going to cook it.
