78 KZ 650 f Timing trouble on 2-3
  • katui
  • katui's Avatar Topic Author
03 Sep 2014 17:25
#646148
SO I have been trouble shooting my KZ 650 for a little while now and I had run into an odd issue.
Symptoms:
Rough idle, sounds like one set of cylinders is running well and the other not
Seems to run decently in low to mid range but once into the 5-6k range it doesn't have a huge amount of power and sounds like it may be stuttering a bit. Worsens by 6-7k.
Problem:
I have cleaned my points, both have some minor pitting in the centre but are otherwise flat and clean.
Point gap is correct (on the wide side of 0.3-0.4mm) ( I do see arcing between the points when running, but I am assuming that is normal)
I bought a timing light, For 1&4 timing at idle and ~3500 RPM to just about right(Perfect at idle and just shy of the double lines at ~3500) BUT at idle n 2&3 the timing is very jittery, varying between F T almost alternating between the two, and at ~3500 is a blur vaguely in the range of the double lines. As well at the higher RPM the strobe doesn't always fire, which would explain the stuttering.
Any educated guesses on what would cause this?
Main three culprit I can think of would be points, condensers, or the 2&3 coil. I should be able to replace the condensers easily enough, might be my next step.
Help/advice would be appreciated!
  • Motor Head
  • Motor Head's Avatar
Re: 78 KZ 650 f Timing trouble on 2-3
03 Sep 2014 20:29
#646187
You sound on the right track. Replace the points and condensers first, or switch to an electronic ignition.
You could still have another issue such as a bad coil, or a bad plug wire/ wire cap. Could be a wiring connection. You could swap the two coils out, and see if the problem moves with the coil.
  • katui
03 Sep 2014 20:52
#646192
Smart idea on swapping the coil to diagnose. I'll look into that come morning.
  • steell
  • steell's Avatar
06 Sep 2014 18:50
#646490
Take the point cover off and start the bike when it's dark,
then look at the area of the points.
  • katui
07 Sep 2014 11:07
#646583
They do spark a fair bit.
  • kz650guy123
  • kz650guy123's Avatar
08 Sep 2015 05:10
#689123
Did you ever find the problem for the timing jitter on 2 and 3 ?
My kz650 is doing the exact same thing.
The spark plug wires on my 2-3 coil don't reach the 1-4 spark plugs.
It would be nice to know before I go out and buy a new coil.
thanks
  • missionkz
  • missionkz's Avatar
08 Sep 2015 09:07
#689169
I pulled the capacitors out of mine and measured them this weekend.
One was a about .26uF and the other is now about .091uF...
Maybe it's not surprising is that the one that measures .091uF has points that are sparking a bit more then I'd like....
but the bike runs good and I don't really notice an annoying misfire.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • kz650guy123
08 Sep 2015 11:41
#689186
I also measured the condensers. Both are almost exactly .26 micro farads. I don't see much sparking.
I've spent most of the day trying different things. I did try switching the condenser wires but no change.
Replaced the 2-3 points also with no change. I also went as far as to swap coils around hoping that the symptom
would follow the coil. It did not.
So using the timing light I still have quite a bit of jitter on 2-3 and 1-4 are rock steady !?!?!?!?
I can't figure it out. What am I overlooking ???
  • kz650guy123
19 Sep 2015 11:42
#690862
I found another thread on this forum discussing this exact same issue. The thinking there is that this is a mechanical problem.
www.kzrider.com/forum/4-electrical/30581...-you?start=20#634123
Probably weak springs on the advancer.
I just can't understand how it can affect only one set of points ???
Seems to me that if the advance is jittering on one set it would affect the other since they are mechanically connected.
