I go through a battery charge after a 2 hour ride. 74 KZ400
- Nolando
26 Aug 2014 16:42
I trickle charge every night. The battery is an older one so that might be a start of the problem, but I am wondering why, after a couple hours, the bike will sputter and lose power above 3500 RPM and my headlight won't work. I will put it on the charger and bam, everything works. Is there some kind of generator or alternator I should try to look and for answers? What kind of battery do you guys use? Mine is a cheap one with liquid cells. Do you guys use gel cell or some other kind of battery?
*SIDE NOTE* bike is hacked up as a bobber so wiring is all a little screwy but it all works the way it should.
Re: I go through a battery charge after a 2 hour ride. 74 KZ400
26 Aug 2014 18:16 - 27 Aug 2014 04:43
You'll need a multimeter to check stuff. It could be that the battery won't charge fully or doesn't hold a charge, or a problem w the charging system. There should be charging system checks outlined in the manual.
Ctek US 0.8 smart charger & a VC97 digital multimeter.
My next battery is probably going to be one of these.
batterystuff.com --- YT12C Scorpion 12v 180 CCA Sealed AGM Motorcycle Battery
Last edit: 27 Aug 2014 04:43 by martin_csr.
- MFolks
26 Aug 2014 19:47
Go to
www.electrosport.com
and find their troubleshooting page, It will show you what to look for when testing for charging problems.
- Nolando
Re: Re:I go through a battery charge after a 2 hour ride. 74 KZ400
26 Aug 2014 20:21
Alright. I'll have to find a manual on the web somewhere. I barely made it home today. Ended up having a top speed of 35 in 5th gear. Couldn't go above 2200 RPM.
- bountyhunter
26 Aug 2014 21:00 - 26 Aug 2014 21:18Yeah......... your alternator/regulator is not putting out any juice.Nolando wrote: I trickle charge every night. The battery is an older one so that might be a start of the problem, but I am wondering why, after a couple hours, the bike will sputter and lose power above 3500 RPM and my headlight won't work. I will put it on the charger and bam, everything works. Is there some kind of generator or alternator I should try to look and for answers?.
Last edit: 26 Aug 2014 21:18 by bountyhunter.
The following user(s) said Thank You: Tomolu5
- bountyhunter
26 Aug 2014 21:19I thought they had them here?Nolando wrote: Alright. I'll have to find a manual on the web somewhere.
27 Aug 2014 04:41Please Log in or Create an account to join the conversation.
- pete greek1
27 Aug 2014 08:30
Since you say it's an old battery ,You can also take the battery to an Autozone & they will check it for free
Have you checked the fluid levels in the battery ??
Pete
Pete
- Nolando
27 Aug 2014 17:07
Fluid levels are good. I work at a tire and battery center so I tested it and came up bad (54 CCA). I bought a new battery at Napa and am letting the acid sit before a charge.
- Nolando
27 Aug 2014 17:43
Am I supposed to be looking at the dynamo field coil? I know nothing of stator ignition systems.
- loudhvx
27 Aug 2014 20:00
The manual will describe a test where you bypass the regulator. This will test teh field coil and stator simultaneously. If that test passes, then you likely need a rectifier or regulator.
Oregonmotorcycleparts.com can help you with those.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Nolando
28 Aug 2014 09:35
Put a new battery in it just so I can get to work. Still trying to find the test for the rest of it. All my parts are in different spots than stock.
