1978 kawasaki kz650 starting problem
  • drotti2004
  • drotti2004's Avatar Topic Author
23 Aug 2014 13:25
#644911
my bike will turn over and start fine when cold but once I drive it and it is warmed up I go to start it and it turns over a lot before it starts. is it the advancer is the timing off or a bad starter?
Re: 1978 kawasaki kz650 starting problem
23 Aug 2014 13:56
#644913
If the starter is cranking the engine over the problem isn't the starter. It could just be that you need a tune-up. Ignition timing, carbs, valve clearances, etc. should be checked periodically and adjusted as needed. The owner manual and Kawasaki Service Manual both show the maintenance schedule. Ed
  • drotti2004
13 Jul 2015 18:08
#680746
actually when it doe this i dont think it is turning the engine over its just the stater making a grinding like sound until it hits the right spot then the engine will start ... probably bad stater right?
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Re:1978 kawasaki kz650 starting problem
13 Jul 2015 18:22
#680747
If the starter motor is turning but the crankshaft isn't then the starter's one-way clutch is going/gone out.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • KZB2 650
  • KZB2 650's Avatar
13 Jul 2015 18:23
#680748
Search starter clutch.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • drotti2004
14 Jul 2015 17:59
#680882
well its sounds like the stater clutch is going and i don't really want to tear it apart to fix it ,so i thought i would just use the kickstarter but that has problems to most of the time it doesn't grab and turn the engine a lot of play in the shaft back and fourth too does this require taking the engine apart too .
