Coil pack
  • koloj
  • koloj's Avatar Topic Author
Coil pack
21 Aug 2014 22:16
#644745
I have 1980 KZ750 four if your looking at the coil pack from the side which wire goes on top conector red or black and does it matter same with can either of the two pair of wires go on either coil just like to know wire diagrams so plain...if they aren't interchangeable how would I go about finding which wires goto what coil pack thank ya much
  • azman857
  • azman857's Avatar
Re: Coil pack
21 Aug 2014 22:31 - 21 Aug 2014 22:32
#644749
I don't think it matters which way a coils primary is hooked up. As for which set of wire goes to which coil. Hook em up and try to start it up. If it don't, swap wires to coils. Hopefully one with more experience will pipe up.
Last edit: 21 Aug 2014 22:32 by azman857.
  • martin_csr
  • martin_csr's Avatar
Re: Coil pack
22 Aug 2014 05:39 - 22 Aug 2014 05:41
#644762
The750-4 manual doesn't seem to indicate polarity. You could examine yours to see if they are marked. The stock coils of my 81 650-CSR are embossed w pos (+) & neg (-) symbols and the manual indicates what wires go where (red to pos & black or green to neg).
KZ650-CSR & KZ750-4.
Right side coil = #1 & #4 = red/black igniter leads
Left side coil = #2 & #3 = red/green igniter leads
Last edit: 22 Aug 2014 05:41 by martin_csr.
  • koloj
Re: Re:Coil pack
22 Aug 2014 07:37
#644781
Right and left sitting on the bike or looking from front
  • MFolks
  • MFolks's Avatar
Re: Re:Coil pack
22 Aug 2014 08:48
#644788
On the seat, left to right, 1,2,3, & 4
  • koloj
Re: Re:Coil pack
22 Aug 2014 11:24
#644798
Cool thanks
