Microsquirt Ignition Inputs
- diego092409
13 Aug 2014 13:02
For those of you who have played with the microsquirt controller, have any of you had success with using the dual spark output control to run the ignition timing? I am reading the documentation and it states that you can use the Tach inputs coming from the distributor for the timing inputs. Can you use the input signals coming from the electronic ignition on the newer KZ's for the tach inputs like they are stating?
www.useasydocs.com/details/dualspark.htm
1982 KZ1100 B2 - 'Old Red'
kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
2015 BMW K1600GT
- steell
Re: Microsquirt Ignition Inputs
14 Aug 2014 21:43 - 14 Aug 2014 21:45
Yes you can use the electronic ignition pickups, that's the standard way.
But, if your MicroSquirt is a recent one, you can't drive coils directly from the MicroSquirt because coils draw to many amps. You'll need a couple of ignition drivers, like these:
Diyautotune sells them, and they are very helpful.
Last edit: 14 Aug 2014 21:45 by steell.
