KZ550 LTD Tachometer/Voltmeter gauge issues
  • Recoil
  • Recoil's Avatar Topic Author
07 Aug 2014 09:50
#643043
Hello, I recently purchased a 83' KZ550 LTD (Title claims 84'). Not new to bikes, just new to Kaw and these forums...
Sorry if post is a bit long-winded.
The bike had obviously went down a couple of times in its lifetime, nothing major... tip overs + minor spills. A recent flop badly damaged the speedo. Engine is sound. This bike has the tach w/ built in voltage indicator. The only notable issues are the speedometer and center panel were smashed up including the voltage switch. New speedometer is on order, but decided to remove the damaged junk speedo and voltage switch while cleaning the dash area. Snipped the wires. The tach+voltage gauge were working excellent before cutting the wires.
Rigged a on-off-on toggle switch in the old voltage switches place in the meantime. This allows me to check the volts properly still using the switch. However, the tachometer itself is reading off around 3-3.5k rpms where it should be reading 1-1.5k rpms(needle still spins up). Any ideas? Did the factory switch have a built-in resistor or overlooking something else? Diagrams haven't helped much other than to lead me to believe that the cut Brown wire that went to the speedo has left a circuit open.
Any help is greatly appreciated. Thx
KZ550 LTD
  • Recoil
Re: KZ550 LTD Tachometer/Voltmeter gauge issues
07 Aug 2014 09:55
#643045
AND this should be tagged under electrical... sry
KZ550 LTD
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
07 Aug 2014 10:49
#643048
Most electronic tachs can usually be switched between two ranges. With a wasted spark system, the ignition is firing every 360 degrees of crank rotation on 4-cylinder bikes versus 720 degrees on many twins and singles.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • Recoil
07 Aug 2014 11:12
#643052
I may have overlooked the switch then... I will take a look tonight.
KZ550 LTD
  • Recoil
11 Aug 2014 07:58
#643465
No luck, couldn't locate any such internal switch (stock tach). Tried a few different connections, also tried resistors on the tach sense line, but that just halted the needle from climbing when throttle is applied. The voltage readout is normal when switched on that function... stumped.
Seems like maybe the harness could have been modified at some point so I'm open to other ideas if anyone has any? Thanks!
KZ550 LTD
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
15 Aug 2014 10:14
#644050
As to your original post, unfortunately, I have no idea...But for future reference, you might want to get out of the habit of "snipping" wires...pretty much everything in the wiring harness on these old gals is plugged together with bullet connectors or multi-pin plugs, allowing one to simply unplug/replace components...much easier to install replacement parts and greatly reduces time spent searching for electrical gremlins (potentially caused by home-spun splices)...Good luck with her!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • Recoil
15 Aug 2014 11:11
#644064
Thanks for the advise... It's not a regular habit to do so, unfortunately there wasn't any saving the items "snipped" off in this case. All my new connections are being done properly using new bullet connectors, multi-pins, and proper soldering when needed. The wiring from the seat back was terrible, every wire was color swapped for whatever a PO had readily available, pink, white, etc. Needless to say, home-spun splices may have caused this particular gremlin. Can't be too upset... It was a screaming deal for the overall condition.
The bike is not beyond remedy, and coming right along one improvement at a time. The new speedometer and turn indicators have been installed and no complications are left regarding the voltage switch. Just that the tach still seems to read high. Extensive Internet searches have yielded no results. Still hoping somebody has maybe ran into it before... while I retrace my wires.
KZ550 LTD
