1979 KZ400 rubber battery strap
- ottothecow
05 Aug 2014 07:58
Does anyone know where I can get a replacement rubber strap that holds the battery in to my 1979 kz400? Snapped off while riding.
If there are no direct replacements, does anyone know how long the strap measures? I see a bunch of replacements for other bikes that look like they would fit, but I need to find something the right length.
Thanks
Thanks
1979 KZ400
- D3
Re: 1979 KZ400 rubber battery strap
05 Aug 2014 08:47
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
[URL[/IMG][/URL]
The following user(s) said Thank You: ottothecow
05 Aug 2014 08:51 - 05 Aug 2014 09:16
According to the cross-reference at Kawasaki.com, the Battery Band (92072-006) is still an Active part & was used on a bunch of models, including the 2001 ZX600 & 03 ZX-7R, et al.
At places such as RonAyers or Partzilla it's listed for around $5 or $6.
Several on eebbaayy are $20-25, ouch, but you can find them there for less than that.
Last edit: 05 Aug 2014 09:16 by martin_csr.
- ottothecow
05 Aug 2014 09:36
From those ebay pictures, the 92072-006 looks too short, but maybe mine was just really stretched out.
for $5, I will give it a try.
Thanks
Thanks
1979 KZ400
- MFolks
05 Aug 2014 09:37
When you get the new strap, clean it with soap and water, let it dry, and then spray on some Silicone & wipe off the excess. I think your old strap dried out and broke.
The following user(s) said Thank You: PLUMMEN
05 Aug 2014 09:48 - 05 Aug 2014 09:56I guess it's possible the cross-ref info is incorrect, so you should do some poking around the diagrams at Kawasaki.com or Partzilla, and look around eebbaayy some more.ottothecow wrote: From those ebay pictures, the 92072-006 looks too short, but maybe mine was just really stretched out.....
Whenever I need something, Kawasaki.com is just a starting point. Then I check what I actually have & compare it to the Kaw drawings & eebbaayy photos, then decide whether or not the thing will fit.
Edit: 92072-006. L = 142.1 mm. for the 2008 Vulcan 500. 142 mm = 5.6".
Last edit: 05 Aug 2014 09:56 by martin_csr.
