what is this?
- jsnabbs
- 1981 kawiKZ440
what is this?
16 Jul 2014 01:24
Is this the CDI?
If yes what would be the part name in the manuel? just trying to figure out my eletrical plan (i have no idea about eletrics)
many thanks
Attachment IMG_0405.jpg not found
many thanks
TIME TO TRADE IN THE PEDALS FOR SOME POWER
Re: what is this?
16 Jul 2014 07:08 - 16 Jul 2014 07:14
What bike? It appears to be either a fuel check switch, outage indicator switch, or brake light failure indicator switch, etc. It should be listed in the Chassis Electrical Equip parts diagram & on the wiring diagram.
My 81 650 has a switch similar to the one in your photo: it functions to turn on the low fuel warning light & it also serves as the brake light failure switch. Mine has a black-yellow wire, green-white wire, & a yellow wire.
Last edit: 16 Jul 2014 07:14 by martin_csr.
The following user(s) said Thank You: jsnabbs
- loudhvx
Re: what is this?
16 Jul 2014 07:56
Like Martin said, that is a brake light failure flasher on a KZ440.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- jsnabbs
- 1981 kawiKZ440
Re: what is this?
16 Jul 2014 13:24
thanks for the info
